Page 1 of 2
dual e3d v5 mount for rMaxV1 with abs parallel 2 y axis easy
Posted: Sat Mar 15, 2014 2:08 am
by bubbasnow
Re: dual e3d
Posted: Sat Mar 15, 2014 3:06 am
by McSlappy
Ha ha! I'm excited!
Re: dual e3d
Posted: Sat Mar 15, 2014 1:45 pm
bubbasnow wrote:ive started my dual e3d's
Are the components you printed a Thingiverse item? They look really nice.
Re: dual e3d
Posted: Sat Mar 15, 2014 2:09 pm
by bubbasnow
nope i made them
Re: dual e3d
Posted: Sat Mar 15, 2014 4:23 pm
by Glacian22
bubbasnow wrote:nope i made them
Well y'know, sharing is caring.
![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Re: dual e3d
Posted: Sat Mar 15, 2014 5:08 pm
by bubbasnow
gotta get it going first, they might not work well in this revision...i dont want to share something useless!
Re: dual e3d
Posted: Sat Mar 15, 2014 5:19 pm
by Tinyhead
Those parts look super nice.
Re: dual e3d
Posted: Thu Mar 20, 2014 3:34 am
by Christian79
Being a perfectionist myself, I get what you are saying. But one of the best things about a community like ours is "group development", you never know what the user population will come up with.
bubbasnow wrote:gotta get it going first, they might not work well in this revision...i dont want to share something useless!
Re: dual e3d
Posted: Thu Mar 20, 2014 10:56 am
by bubbasnow
well these work so ill post the files tonight when i get home. i do have a few pix
[img]
https://lh3.googleusercontent.com/-Ggvq ... 192554.jpg[/img]
This is my solution to the dual ezstruder.
Re: dual e3d
Posted: Thu Mar 20, 2014 11:07 am
by bubbasnow
my first print with extruder 2 doing support
[img]
https://lh4.googleusercontent.com/-2-Qx ... 235730.jpg[/img]
Re: dual e3d
Posted: Fri Mar 21, 2014 1:12 am
by edge922
Would it be possible to mount them above for more Z clearance or is there no way to fit them that way.
Re: dual e3d
Posted: Fri Mar 21, 2014 9:51 am
by bubbasnow
edge922 wrote:Would it be possible to mount them above for more Z clearance or is there no way to fit them that way.
not with the stock effector plate
![Sad :(](./images/smilies/icon_e_sad.gif)
Re: dual e3d
Posted: Fri Mar 21, 2014 10:24 pm
by bubbasnow
ok here are my files
with this design follow the described order for proper installation.
1. slide both hot ends into the slots
2. snap 1 side of the fan shroud onto the collar just above the top cooling fins.
3. rotate the fan shroud until the second extruder snaps into place.
4. put the clamp over the top of the nozzles to lock them in place.
5. tighten down the ptc connectors all the way and cut the extra plastic flange off of the outside, this is a tight fit and is required to get these to not bind inside the effector plate
[img]
https://lh5.googleusercontent.com/-dEyv ... 154610.jpg[/img]
6. insert screws through head before installation of the fans because they will block the holes, i use a couple tiny drops of superglue instead of screws to hold the 30mm fans in place.
[img]
https://lh3.googleusercontent.com/-FJeB ... 155900.jpg[/img]
7. install the nozzles so they are parallel with the Y axis (6 holes in the effector plate this makes offset in firmware easiest).
8. if shimming is required just loosen the two screws on the nozzle that needs adjustment and insert shim between effector plate and clamp.
let me know if any additional info is needed.
another photo
[img]
https://lh5.googleusercontent.com/-_sO6 ... 155914.jpg[/img]
Re: dual e3d
Posted: Sat Mar 22, 2014 7:18 am
Thank you for posting the files. This is the best setup I have seen and certainly better than anything I have
seen on Thingiverse.
Re: dual e3d
Posted: Sat Mar 22, 2014 7:49 am
What is the offset value you used?
Re: dual e3d
Posted: Sat Mar 22, 2014 2:51 pm
by bubbasnow
i set the offset in eeprom, if you align the nozzles with the y-axis there is no x offset.
Re: dual e3d
Posted: Sat Mar 22, 2014 4:46 pm
Thank you for posting the numbers.
Re: dual e3d
Posted: Mon Mar 24, 2014 1:30 pm
by bubbasnow
here is something i made real quick to test slic3r
[img]
https://lh4.googleusercontent.com/-GA8F ... -no/14+-+1[/img]
Re: dual e3d
Posted: Mon Mar 24, 2014 1:34 pm
I'd say you have your dual extruders working well.
Excellent job!
Re: dual e3d
Posted: Thu Apr 03, 2014 12:06 am
by bubbasnow
Printing some stuff
Sliced in s3d
Re: dual e3d
Posted: Thu Apr 03, 2014 12:17 am
by Tinyhead
That's awesome! Looks super clean! Some of the other setups and results I've seen are nothing compared to what you've got running there.
Re: dual e3d
Posted: Thu Apr 03, 2014 11:43 am
by 0110-m-p
That looks awesome. I'm assuming you used ABS for all the mounts? Seems like PLA that close to the nozzle/heater cartridge would warp really quick due to heat.
Re: dual e3d
Posted: Thu Apr 03, 2014 6:34 pm
by bubbasnow
yar it is orange abs, you could probably get away with PLA, i would just wrap the heater blocks with insulation first.
Re: dual e3d
Posted: Sat Apr 05, 2014 2:02 pm
by bubbasnow
alrighty so i have replaced my temp solution for the dual ezstruders with this.
[img]
https://lh6.googleusercontent.com/-OLX6 ... 114447.jpg[/img]
It fits in the standard holes but i had to drill 2 for the filament to feed down. i am also using some of those filament spool rollers using nylon drawer wheels
[img]
https://encrypted-tbn0.gstatic.com/imag ... D30o9k5oER[/img]
Re: dual e3d
Posted: Sat Apr 05, 2014 2:12 pm
Nice job!
Would you still have the stl for the dual ezstruder mount?
