Frame Kit for Rostock MAX v3
General info from SeeMeCNC HQ
PartDaddy
Post by PartDaddy »
https://www.seemecnc.com/products/frame ... ock-max-v3
photo's soon, shipping approximately Oct 13, save $50 - introductory sale
All major components for the Rostock MAX v3 will be for sale. Please read the product page carefully. We do not include t-slot or electronics because you likely already own what you need to make a v3.
The rev8 heated bed is the same as rev7 but only 1mm thick. I made the heated bed floating on an injection molded bed insulator. The six blue bed clamps should be adjusted to gently grip the glass. Too firm and the glass and be bowed causing a non-flat build surface. << just some notes here. You can use your existing heated bed. We designed the mounting hardware to accept a 1mm to 3mm thick stack. Of course, hack away.
Remember to download the latest firmware and follow the v3 build guides. You can find those under "downloads" on our site.
~PartDaddy
SeeMeCNC Owner & Founder
Since 1996
Return to “General Announcments”
