h-1.1 extruder assembly instructions
Posted: Sat Jan 05, 2013 6:27 pm
by vaporlock
I'm starting my build but can't find any info on how to build the extruder. I found a pdf about the H1 extruder but there are some differences between the one in the drawing and my parts. I can't tell how the Extruder Base and the Lower Extruder Mounting Plate go together. It looks like a bolt goes through an offset hole in the Base through a centered hole/slot in the Plate. In the pictures I can actually see this but it is odd. The H1 drawing shows 2 bolts in the barrel but the one I have has a knurled nut on the end to secure it.
Any help here would be appreciated.
Re: h-1.1 extruder assembly instructions
Posted: Sun Jan 06, 2013 4:26 pm
by thosj
I bought an original H-1 and I bought an H1.1 upgrade on Indiegogo. I have the H1 assembled extruder sitting here and the H1.1 upgrade extruder parts. The parts look the exact same to me sitting here side by side 'cept new ones are black and old ones are clear, so I would simply follow the H1 assembly. If you find something different or something that doesn't work, ask back!!
Posted: Sun Jan 06, 2013 5:01 pm
I've built both and other than the material they are made of they assemble the same.
There is a video showing the assembly here
http://www.youtube.com/watch?v=mua3i_wP32I
Posted: Sun Jan 06, 2013 10:36 pm
by vaporlock
That video was just what I needed. Thank you. Now I understand the offset bolt.
I've been trying to download the H1 manuals but the .com site just slows to a crawl at about 10MB every time I try. The .org site is completely offline more often than not so it has been difficult to get all the files. Could someone put the manual up somewhere or perhaps email it to me?
Posted: Mon Jan 07, 2013 1:54 am
by vaporlock
After 3 days of trying I finally got the assembly manual downloaded. Almost done anyway but now I can double check the dimensions.
