Page 5 of 5
Re: The Ultimate Rostock Thing Collection
Posted: Mon Sep 01, 2014 5:27 pm
by teoman
Does anyone have some stls for some wrenches to adjust the cheapskates?
Posted: Mon Sep 01, 2014 6:08 pm
by DavidF
Posted: Mon Sep 01, 2014 6:09 pm
by DavidF
teoman wrote:Does anyone have some stls for some wrenches to adjust the cheapskates?
Applying mechanical advantage to the cheapskates would not be a good idea. Now a weighted wrench that would apply the right pressure wouldnt be a bad idea....
Posted: Mon Sep 01, 2014 6:33 pm
by Kevinvandeusen
wasn't it like 2 5/16" wrenches?
Posted: Mon Sep 01, 2014 6:43 pm
by teoman
DavidF wrote:teoman wrote:Does anyone have some stls for some wrenches to adjust the cheapskates?
That is what the manual says??
Posted: Mon Sep 01, 2014 7:08 pm
by DavidF
teoman wrote:DavidF wrote:teoman wrote:Does anyone have some stls for some wrenches to adjust the cheapskates?
That is what the manual says??[/quote
The manual shows the proper adjustment ( how they roll) in the video. Yes they say use a 7/16 wrench to do it. But that is with everything disconnected ie belts and arms.
That's why I suggested a weighted wrench to apply the proper tension. Some may be heavy handed when it comes to adjusting them without being able to slide them up and down. Personally I found it easy to tension them with just my fingers.
Posted: Tue Sep 02, 2014 2:07 am
by teoman
A weighted wrench or a torque wrench would be good.
But as the angle is not fixed maybe a rubber band mechanism would be better.
Posted: Fri Jul 29, 2016 10:51 am
by Lasivian
Another thing to add to the collection:
http://www.thingiverse.com/thing:1695141
It's a cartridge system for spools since I disliked the wooden arm.
I'm not sure if the V2 uses the same spool holders as my V1 that I built this for tho.
[img]
http://thingiverse-production-new.s3.am ... atured.JPG[/img]
Posted: Fri Jul 29, 2016 12:53 pm
by Xenocrates
Looks like a pretty good match for the V2. I have something similar, although it came from someone else, and uses longer cones so that a single set can do more spools, and has a nice big knob on the end. But jeeze, that's a lot of spool holders. how many do you use at once?
