Increasing Max Temperature.
Is the extruder temperature limited by Repetier? or is it limited in the firmware? And how do I change it?
Re: Increasing Max Temperature.
It is limited in firmware.Mac The Knife wrote:Is the extruder temperature limited by Repetier? or is it limited in the firmware? And how do I change it?
You need to edit your configuration.h looking for max_temp for the extruder (hotend)
See this link: http://forum.seemecnc.com/viewtopic.php?f=60&t=5343" onclick="window.open(this.href);return false;
Now I see it. I had assumed it would be with the extruder settings, not below the bed settings. Line 575
Thanks.
Thanks.
I am just glad that you found it. Navigating those config files can be a bear, nothing is where you expect it to be.Mac The Knife wrote:Now I see it. I had assumed it would be with the extruder settings, not below the bed settings. Line 575
Thanks.
Happy Printing!
Here's the next problem,,,,,, If I try to adjust the temperature while the printer is running, It drops to 240, and will not go back up. Is that also in the config h file?
Knife,
Did you ever figure out a way around not being able to adjust the temp from the LCD? I am having the same issue. I can hit 275 through Repetier Host, but trying to adjust with LCD max is still 240.
Mike
Mike
Disregard! I found it in configuration.h under #define UI_SET_MAX_EXTRUDER_TEMP
Sorry about that,, Yeah, that setting is down around line 900. They really make you hunt around for the settings.
On mine it's line 1240, took a while to dig down there.
