Just Fits (Part Daddy in Trailer)
http://makerhive.proboards.com/thread/9 ... dy-trailer" onclick="window.open(this.href);return false;
Re: Just Fits (Part Daddy in Trailer)
One more inch and the door would not close. Great that it did fit!
prob. less than an inch even! The rubber feet need to be removed, or the doors don't close
Your problem is that you need one of these, and a printer to fill it:
https://www.dropbox.com/s/3cjyspp8jl4uc ... _.jpg?dl=0
You're not straight out'a Compton.....Your straight out of the trailer! Good luck guy's! Also does anyone know how many amp's a 12 volt heater cartridge pulls. i'm going to try to mod my seeme for those.
I thought they are rated at 30W, so 2.5 A. I = P/V (E is the same as V)
[Edit] So if they are 40W, that's 3.3A
[img]http://upload.wikimedia.org/wikipedia/c ... _chart.svg[/img]
- jdurand
The ones I've seen are 40W.
Just remember, small changes in voltage lead to big changes in Wattage. That's why I have #4 (5.2 square mm) wire for my small solar panels, our building code understands this.
A 10% decrease in voltage is a 19% decrease in Wattage!
Doubling the voltage is a 400% increase in Wattage.
Thank's .... I put one of those heater cartridges in my seeme hot end .... And now ... My power supply fan run's... All the time.
