Extruder skipping
Posted: Thu Feb 20, 2020 7:05 pm
by Vic
I have an Orion which is about 5-6 years old. Updates include e3d hotend and ballcup arms and platform. I have it calibrated very well and have been very pleased with the performance.
Recently the extruder started to skip. I updated to the EZR thinking it was a bad hobbed gear. No help. It seems to not have enough torque to push the filament. The hotend heats up well. I can manually extrude by turning the knob. I reflashed the firmware with increased stepper current from 130 to 140. I also disassembled the hotend and it looked good without any obstruction and the nozzle is clear.
I have searched to forum as well as google and can't come up with any other ideas.
Could the stepper motor be bad?
Any help would be greatly appreciated.
Re: Extruder skipping
Posted: Fri Feb 21, 2020 7:35 am
The motor should be ok - I would check to make sure that the wiring is ok. There might be a nearly-failed crimp at the connector end.
Posted: Fri Feb 21, 2020 7:49 am
by Vic
Thanks I'll check it
Posted: Sat Feb 20, 2021 11:28 pm
by DDXdesign
I wonder if the OP ever got that figured out. My new Artemis is doing it a lot too - the classic 'you're too low or trying to feed too fast' backlash, but I've changed the babystepping, increased the temp, lowered the speed...
Posted: Sun Feb 21, 2021 12:25 pm
What exactly do you mean by "changed the babystepping"?
