MAX METAL poll -build right or upside down?
Such as Laser cutters (Must use the phrase 'sharks with frickin lazors' once per thread)
How are you building your machine, "normal" or "upside down"
Normal (motors, electronics, lcd & psu on bottom)
8
47%
Upside Down (motors, electronics and lcd on top, psu on bottom)
9
53%
Other
0
No votes
Total votes: 17
bvandiepenbos
Post by bvandiepenbos »
How are you building yours?
miglo
Re: MAX METAL poll -build right or upside down?
Post by miglo »
Opting for "normal style". I don't want my printer to be top heavy.
bob64
Post by bob64 »
If you mount your power supply to the base, that'll solve the "top heavy" problem.
Rostock Max V2 with mods:
E3d v6 with 713maker mount & e3d titan extruder
Tricklaser CF arms, heat spreader, tricktrucks, fly-n-strude, metal carriage & effector
Duet v.8.5.0
24v MeanWell 750w PS & Cydom D1D40 SSR in parallel with stock 12v PS
miglo
Post by miglo »
I ended up moving the PSU completely outside the enclosure bc prevent overheating.
What's the advantage of flipping it upside down?
Update:. Ah I guess it would make wiring easier. Too late now.
626Pilot
Post by 626Pilot »
I ran some of the Trick Laser 8-conductor wire up one of the insides of the channels. That takes care of the endstops. For the hot end wiring, I use a cable mast: http://www.thingiverse.com/thing:1554882
Return to “Other Machines”
