Let me be one of the first:)
Batteau62
Post by Batteau62 »
Trying to print a pulley, it started to pop loose about 3/4 through, severe ABS curl. Lesson learned: When something is symetrical, probably better to print it as halves and assemble later ;) Rookie mistake :oops:
Flateric
Re: Let me be one of the first:)
Post by Flateric »
Print with UHU glue stick covered glass at around 90-100c for ABS with a skirt of 5-15mm and your all set and no more curl.
Also, you have way too much plastic being extruded and looks like 100% infill, both of these will also doom you to curl city.
WAY too much plastic being printed there. Have you calibrated your extruder?
Batteau62
Post by Batteau62 »
This was very early on for me. I've "learned" a lot since :) I was just trying to get the ball rolling on this sub-forum since I proposed it. :D Having said that, come on guys, give up those epic fails! :lol:
edward
Post by edward »
I would probably also caution the use of the giant fan in the background. That massive airflow is causing uneven cooling which is going to introduce all sorts of internal stresses, inducing warp.
Consider a localized fan (duct) on your effector, and leave it turned off for the first several layers so as not to cause early shrinkage.
Flateric
Post by Flateric »
That's right!
Cause no-one likes shrinkage! Not you, not the girls at the pool you want to impress!
I also feel the use of a aluminium heat spreader/evener plate under the glass helps in many ways. Another really essential upgrade IMO.
Flateric
Post by Flateric »
Batteau62 wrote:This was very early on for me. I've "learned" a lot since :) I was just trying to get the ball rolling on this sub-forum since I proposed it. :D Having said that, come on guys, give up those epic fails! :lol:
Oh I am sure, I just think the the fail photos should also allow for discussions on what to do to correct so that the forums is a resource for others to look at and go "Hey I have that problem!" With the discussion detailing how to fix it.
Batteau62
Post by Batteau62 »
That is exactly what John said:
johnoly99 wrote:I love it!
Yes, yes it does. Soooo
http://forum.seemecnc.com/viewforum.php?f=62
Now, to make it valuable to the community, don't just post pics of the fail, give some description as to what you think caused it. So that way, we not only get a laugh, but we'll learn at the same time :D
This was my original post to propose the subforum:
http://forum.seemecnc.com/viewtopic.php?f=59&t=2478
So now...SOMEONE ELSE POST SOME FAIL PICS!! :D
lordbinky
Post by lordbinky »
I haven't documented my attempts as well as I could have, but rest assured my printer will get bored of what I want to print and attempt to make more abstract art again.
edward
Post by edward »
Flateric wrote:That's right!
:lol:
I have nothing else I can say...
