Couple issues of prints
Posted: Fri Nov 18, 2016 7:11 pm
by jreyes
Hasn’t been going well for me for this month. For some reason I can’t get a good print.
The green one is a good print before messing with the hotend. Now it print ok but some prints are coming out really bad. The white one is example.
Re: Couple issues of prints
Posted: Sun Nov 20, 2016 3:40 pm
by IMBoring25
Looks like the motion is still solid. Maybe an intermittent partial clog?
Posted: Sun Nov 20, 2016 6:58 pm
by joe
Look like a combination of over extrusion, poor cooling, print speed a little high. Your retraction may be off too as I see a lot of stringing.
So 1, check your extrusion first. Does it extrude 100mm when asked - disconnect the bowden tube from the hotend a measure from there.
2, slow down to 20 - 30mm/s and start from there.
3, your fans should be 100%
Then fool around with retraction. Do each step separately and look at the result. Have you check the hotend temp with a meter? it may be printing way to hot.
Posted: Tue Nov 22, 2016 8:55 pm
by jreyes
Thanks for your the reply's
I will go to each steps and see troubleshoot it and get back to you
