HE280 Bed Levelling issues w/ Oldschool Carriage/Arms/Platform
Posted: Thu Sep 29, 2016 9:46 pm
Got my printer to the point where I can start "auto-calibrating".
I altered my configuration.h as follows:
-Set the printer as "V3", (5).
-Reversed the proper axis to match V2.
-Altered the effector/arm length/etc. to match the stock V2 carriage/arms as described in https://github.com/seemecnc/Repetier-09 ... guration.h
Ran the calibration and this is my first test:
[img]http://i.imgur.com/Gz3PKeQ.jpg[/img]
So I though, ok fine, I'll tell it's a V2, and adjust the the offsets for that:
[img]http://i.imgur.com/AHjndWp.jpg[/img]
So not much success here. Anybody have any suggestions? Maybe I misssed something???
Lastly, fun lesson learned today: Cold basements cause thermistor errors, which in turn cause your printer not to work... the fix is in the firmware =_= good times.
#define PRINTER 5Code: Select all
// ###### Inverting Axis Settings
#elif PRINTER == 5
#define INVERT_X_DIR 1
#define INVERT_Y_DIR 0
#define INVERT_Z_DIR 1
#endif
#elif PRINTER == 5 // Rostock MAX v3
#define DELTA_DIAGONAL_ROD 269.0 // oldschool arms
#define DELTA_MAX_RADIUS 200.0
#define PRINTER_RADIUS 200.0
#define Z_MAX_LENGTH 350
#define END_EFFECTOR_HORIZONTAL_OFFSET 33.0 // oldschool offset
#define CARRIAGE_HORIZONTAL_OFFSET 38.4 // oldschool carriages[img]http://i.imgur.com/Gz3PKeQ.jpg[/img]
