At first I thought the problem was with the stock heater resistors, so I swapped the extruder with a HE280 hotend. Same problem, even after many PID autocalibrate attempts (It just gave me values close to default). I thought that I might have built the hotend incorrectly so I swapped the hotend with a different HE280 hotend. Still the same problem. At this point I'm at a complete loss. I've checked all the wiring on the RAMBO and it seems fine. Should the layer fans be off while the raft is printing? I can't find where to configure this for the HE280 other than the front panel (Using Mattercontrol). I guess I should outline a bit about the printer's history.
- -The kit sat around for about a year waiting to get built (shipped Nov. 2015)
-Once assembled, the RAMBO was found to be faulty and was replaced (August 2016)
-After replacement, the printer experienced repeated heater decoupling errors. It was found that the hotend thermistor was pulled out. We are curious if this failure damaged the power supply due to overheating, but the printer does not seem to be currently browning out. It does share an outlet with two other V2s.(Sept. 2016)
-The printer in its stock configuration worked well enough for a while but experienced heating issues about 3 weeks ago (Oct. 2016)
-Hotend was replaced twice with HE280. Both HE280s tried shipped in the same package. The first one tried to run itself through the build plate on leveling calibration, but the second did not. (Nov 2016)
