# Robot module configurations : general handling of movement G-codes and slicing into moves
arm_solution linear_delta # delta selection
arm_length 468.3 # this is the length of an arm from hinge to hinge
arm_radius 206 # this is the horiontal distance from hinge to hinge when the effector is centered
default_feed_rate 8000 # Default rate ( mm/minute ) for G1/G2/G3 moves
default_seek_rate 8000 # Default rate ( mm/minute ) for G0 moves
mm_per_arc_segment 0.5 # Arcs are cut into segments ( lines ), this is the length for these segments. Smaller values mean more resolution, higher values mean faster computation
#mm_per_line_segment 5 # Lines can be cut into segments ( not usefull with cartesian coordinates robots ).
delta_segments_per_second 100 # segments per second used for deltas
# Arm solution configuration : Cartesian robot. Translates mm positions into stepper positions
alpha_steps_per_mm 107 # Steps per mm for alpha stepper
beta_steps_per_mm 107 # Steps per mm for beta stepper
gamma_steps_per_mm 107 # Steps per mm for gamma stepper
# Planner module configuration : Look-ahead and acceleration configuration
planner_queue_size 32 # DO NOT CHANGE THIS UNLESS YOU KNOW EXACTLY WHAT YOUR ARE DOING
acceleration 1000 # Acceleration in mm/second/second.
acceleration_ticks_per_second 1000 # Number of times per second the speed is updated
junction_deviation 0.05 # Similar to the old "max_jerk", in millimeters, see : https://github.com/grbl/grbl/blob/master/planner.c#L409
# and https://github.com/grbl/grbl/wiki/Configuring-Grbl-v0.8 . Lower values mean being more careful, higher values means being faster and have more jerk
# Stepper module configuration
microseconds_per_step_pulse 1 # Duration of step pulses to stepper drivers, in microseconds
minimum_steps_per_minute 1200 # Never step slower than this
base_stepping_frequency 100000 # Base frequency for stepping, higher gives smoother movement
# Stepper module pins ( ports, and pin numbers, appending "!" to the number will invert a pin )
alpha_step_pin 2.1 # Pin for alpha stepper step signal
alpha_dir_pin 0.11 # Pin for alpha stepper direction
alpha_en_pin 0.10 # Pin for alpha enable pin
alpha_current 1 # X stepper motor current
alpha_max_rate 12000.0 # mm/min actuator max speed
x_axis_max_speed 12000.0 # mm/min cartesian max speed
beta_step_pin 2.2 # Pin for beta stepper step signal
beta_dir_pin 0.20 # Pin for beta stepper direction
beta_en_pin 0.19 # Pin for beta enable
beta_current 1 # Y stepper motor current
beta_max_rate 12000.0 # mm/min
y_axis_max_speed 12000.0 # mm/min
gamma_step_pin 2.3 # Pin for gamma stepper step signal
gamma_dir_pin 0.22 # Pin for gamma stepper direction
gamma_en_pin 0.21 # Pin for gamma enable
gamma_current 1 # Z stepper motor current
gamma_max_rate 12000.0 # mm/min
z_axis_max_speed 12000.0 # mm/min
# Serial communications configuration ( baud rate default to 9600 if undefined )
uart0.baud_rate 115200 # Baud rate for the default hardware serial port
second_usb_serial_enable false # This enables a second usb serial port (to have both pronterface and a terminal connected)
#msd_disable false # disable the MSD (USB SDCARD) when set to true
# Extruder module configuration
extruder_module_enable true # Whether to activate the extruder module at all. All configuration is ignored if false
extruder_steps_per_mm 710.00 # Steps per mm for extruder stepper
extruder_default_feed_rate 600 # Default rate ( mm/minute ) for moves where only the extruder moves
extruder_acceleration 500 # Acceleration in mm/sec^2 only used for retracts
extruder_max_speed 25 # mm/sec NOTE only used for retracts
extruder_step_pin 2.0 # Pin for extruder step signal
extruder_dir_pin 0.5 # Pin for extruder dir signal
extruder_en_pin 0.4 # Pin for extruder enable signal
delta_current 0.7 # Extruder stepper motor current
# Laser module configuration
laser_module_enable false # Whether to activate the laser module at all. All configuration is ignored if false.
#laser_module_pin 2.7 # this pin will be PWMed to control the laser
#laser_module_max_power 0.8 # this is the maximum duty cycle that will be applied to the laser
#laser_module_tickle_power 0.0 # this duty cycle will be used for travel moves to keep the laser active without actually burning
# Hotend temperature control configuration
temperature_control.hotend.enable true # Whether to activate this ( "hotend" ) module at all. All configuration is ignored if false.
temperature_control.hotend.thermistor_pin 0.24 # Pin for the thermistor to read
temperature_control.hotend.heater_pin 2.5 # Pin that controls the heater
temperature_control.hotend.thermistor EPCOS100K # see src/modules/tools/temperaturecontrol/TemperatureControl.cpp:64 for a list of valid thermistor names
temperature_control.hotend.set_m_code 104 #
temperature_control.hotend.set_and_wait_m_code 109 #
temperature_control.hotend.designator T #
#P39.98 I5.00 D79.91
# temperature_control.hotend.p_factor 39.98 #
# temperature_control.hotend.i_factor 5.00 #
# temperature_control.hotend.d_factor 79.91 #
# For EPCOS B57540G0104F000 Digikey 495-2125-ND change as needed
temperature_control.bed.enable false #
temperature_control.bed.thermistor_pin 0.23 #
temperature_control.bed.heater_pin 2.7 #
temperature_control.bed.beta 4036 #
temperature_control.bed.thermistor EPCOSB57540G0104F000 # B57891S0104F008 Digikey 495-2164-ND
temperature_control.bed.set_m_code 140 #
temperature_control.bed.set_and_wait_m_code 190 #
temperature_control.bed.designator B #
# uncomment followng to use bang bang isntead of PID for the bed (best for relay conrolled hotbeds)
#temperature_control.bed.bang_bang true # set to true to use bang bang control rather than PID
#temperature_control.bed.hysteresis 2.0 # set to the temperature in degrees C to use as hysteresis when using bang bang
# Switch module for fan control
switch.fan.enable true #
switch.fan.input_on_command M106 #
switch.fan.input_off_command M107 #
switch.fan.output_pin 2.4 #
# automatically toggle a switch at a specified temperature
# useful to turn on a fan or water pump to cool the hotend
#temperatureswitch.hotend.enable true #
#temperatureswitch.hotend.type misc # select which MOSFET to use, fan or misc (small MOSFETs)
#temperatureswitch.hotend.threshold_temp 60.0 # temperature to turn on (if rising) or off the switch
#temperatureswitch.hotend.heatup_poll 15 # poll heatup at 15 sec intervals
#temperatureswitch.hotend.cooldown_poll 60 # poll cooldown at 60 sec intervals
# switch.psu.enable true # turn atx on/off
# switch.psu.input_on_command M80 #
# switch.psu.input_off_command M81 #
# switch.psu.output_pin 2.13o! # open drain, inverted
# Switch module for spindle control
#switch.spindle.enable false #
# Endstops
endstops_enable true # the endstop module is enabled by default and can be disabled here
delta_homing true # forces all three axis to home a the same time regardless of what is specified in G28
alpha_max_endstop 1.24^ #
alpha_homing_direction home_to_max # or set to home_to_max and set alpha_max
alpha_min 0 # this gets loaded after homing when home_to_min is set
alpha_max 0 # this gets loaded after homing when home_to_max is set
beta_max_endstop 1.26^ #
beta_homing_direction home_to_max #
beta_min 0 #
beta_max 0 #
gamma_max_endstop 1.28^ #
gamma_homing_direction home_to_max #
gamma_min 0 #
gamma_max 859 #924 # change to suit your height
alpha_limit_enable false # set to true to enable X min and max limit switches
beta_limit_enable false # set to true to enable Y min and max limit switches
gamma_limit_enable false # set to true to enable Z min and max limit switches
#probe endstop
#probe_pin 1.29 # optional pin for probe 1.29
alpha_fast_homing_rate_mm_s 35 # feedrates in mm/second
beta_fast_homing_rate_mm_s 35 # "
gamma_fast_homing_rate_mm_s 35 # "
alpha_slow_homing_rate_mm_s 5 # "
beta_slow_homing_rate_mm_s 5 # "
gamma_slow_homing_rate_mm_s 5 # "
alpha_homing_retract_mm 5 # distance in mm
beta_homing_retract_mm 5 # "
gamma_homing_retract_mm 5 # "
alpha_trim 0 # software trim for alpha stepper endstop (in mm) - moves down
beta_trim 0 # software trim for beta stepper endstop (in mm)
gamma_trim 0 # software trim for gamma stepper endstop (in mm)
# optional Z probe http://smoothieware.org/zprobe
zprobe.enable true # set to true to enable a zprobe
zprobe.probe_pin 1.29 # pin probe is attached to if NC remove the !
zprobe.slow_feedrate 5 # mm/sec probe feed rate
#zprobe.debounce_count 100 # set if noisy
zprobe.fast_feedrate 100 # move feedrate
zprobe.probe_height 10 # how much above bed to start probe
# associated with zprobe the leveling strategy to use
leveling-strategy.delta-calibration.enable true # basic delta calibration
leveling-strategy.delta-calibration.radius 100 # the probe radius
# Pause button
pause_button_enable true #
# Panel http://smoothieware.org/panel
panel.enable false # set to true to enable the panel code
panel.lcd viki_lcd # set type of panel also viki_lcd, i2c_lcd is a generic i2c panel, panelolu2
panel.encoder_a_pin 3.25!^ # encoder pin
panel.encoder_b_pin 3.26!^ # encoder pin
panel.i2c_pins 3 # set i2c channel to use
panel.menu_offset 1 # some panels will need 1 here
panel.alpha_jog_feedrate 6000 # x jogging feedrate in mm/min
panel.beta_jog_feedrate 6000 # y jogging feedrate in mm/min
panel.gamma_jog_feedrate 200 # z jogging feedrate in mm/min
panel.hotend_temperature 185 # temp to set hotend when preheat is selected
panel.bed_temperature 60 # temp to set bed when preheat is selected
# Azteeg specific settings do not change
currentcontrol_module_enable true #
digipot_max_current 2.4 # max current
digipot_factor 106.0 # factor for converting current to digipot value
return_error_on_unhandled_gcode false #
