X3 Pro mount for R.MAX v2?
- Renha
How one could mount it? Has anybody created mounting parts?
3D printing is magic!
Re: X3 Pro mount for R.MAX v2?
I have one I made for the V2 RAMBo mount, but it doesn't come out once put in place since the X3 Pro is so wide. It's made for laser cutting, I can post it later.
Attached a DXF and DWG
- AzteegX3ProMount.dxf
- (131.12 KiB) Downloaded 457 times
- AzteegX3ProMount.dwg
- (32.84 KiB) Downloaded 431 times
- Renha
thank you! what width?
I designed it in mm, its around 161mm in width, unless you're talking about material thickness? In which case its just 1/4", same thickness at the rest of the machine.
- Renha
I'm sorry (my engrish is wery well), I mean thickness, thank you for so smart answer!
