BeBoPr++
bubbasnow
BeBoPr++
Post by bubbasnow »
I picked 2 of these up a while back finally getting time to document the work ive been doing getting this to work with a delta.
Ive populated it with 4 http://www.panucatt.com/product_p/sd8825.htm
[img]http://cdn3.volusion.com/pgsmd.pvnjz/v/ ... 1386069415[/img]
Ill be powering it with http://www.ebay.com/itm/271159932338?ss ... 1497.l2649
[img]http://i.ebayimg.com/00/s/NTAwWDUwMA==/ ... ~60_12.JPG[/img]
Im controlling it with https://www.adafruit.com/product/1876
[img]https://www.adafruit.com/images/970x728/1876-01.jpg[/img]
ive flashed the eMMC with the 7.4 machinekit image from here http://www.machinekit.net/deb/rootfs/wheezy/
[img]http://linuxcnc.org/templates/linuxcnc- ... c_logo.png[/img]
teoman
Re: BeBoPr++
Post by teoman »
Did you manage to get it working with LinuxCNC?
The more i fiddle with the printer, the more upgrades i want to do. And linux seems like a good route.
bubbasnow
Re: BeBoPr++
Post by bubbasnow »
626Pilot
Re: BeBoPr++
Post by 626Pilot »
I'm trying to get some more information put together while I evaluate the BeagleBone solution. Can you post:
- What OS you're using, how you downloaded it, and how you flashed it
- How you installed MachineKit
- What display you're using, where you got it, and what you had to do to set it up
- Where you got your hardware
- Anything else that might have changed since you started the thread
bubbasnow
Re: BeBoPr++
Post by bubbasnow »
626Pilot wrote:I'm trying to get some more information put together while I evaluate the BeagleBone solution. Can you post:
Sorry was away for the week,
-OS is debian, standard for revC versions of BBB
-Machinekit was pre-installed ver 2.7 pre
-I have a monitor directly hooked up, i an running TKEMC interface because large gcode files crash axis interface, hdmi port is supported out of the box.
-I purchased bebopr++ and pepper and step-5 directly from the creator Bas.
-stuff ive changed... ive had to update addresses of file locations because of the newer methods of configurations that machinekit uses.
Return to “Beaglebone Black”
