A silly question is the one that is not asked
Vat designs and coatings etc..., Electronics and mods, Z stages and mechanisms to release the prints from Vats etc...
carlsgems
Post by carlsgems »
I have gotten the Droplit going and have been able to manual control in Gcode sender and in creation workshop, The question is a directional one, when controlling the Z axis for calibrating etc the control arrows are reversed Plus Z goes down Minus Z goes up, is the correct for a bottom up printer like the droplit? Not sure on this, wiring is correct per build manual or do I switch something in config? Thanks in advance for correct solution.
jlmccuan
Re: A silly question is the one that is not asked
Post by jlmccuan »
You can edit the firmware or reverse the stepper wires. If your stepper moves twice the distance it should, pull the jumper on the board to enable microstepping.
carlsgems
Post by carlsgems »
Thanks, I was able to switch the signal wires with success and pulled the jumper and tested distance control with micrometer. Now have coated resin dish with slyguard 184 and curing. Now to calibrate the projector and hope to get test printing after dish has cured.
Return to “DropLit”
