I'm a novice at this with an Orion printer, 0.83 firmware. I downloaded a pyramid model (Giza_main.stl) from Thingiverse, sliced it using Cura and printed it in PLA. The print unceremoniously stopped at 79%. So I ran the model through Meshmixer, which "fixed" several problems. Printing it again, it stopped at 79%. It turns the build platform and extruder off, but leaves the steppers on. When I hit "Home All" it stops about six inches from the endstops.
Anyone have an idea what is going on?
Giza Freezup
IMBoring25
Re: Giza Freezup
Are you printing off SD or over USB from a PC? If the latter, does 79% approximate the elapsed time that corresponds to a sleep or hibernate timer on the computer?
JerryFuller
- Noob
Re: Giza Freezup
That's a good thought, but I'm running off the SD card.
Thanks
Thanks
Re: Giza Freezup
If the USB cable is still connected to the computer, it can still cause interuptions if the computer goes to sleep, especially if you are using mattercontrol.
Re: Giza Freezup
.83 brach is really old. I'd grab the latest from SeeMe if I were you, the older versions have issues like you've noticed.
This post is in the wrong subforum, it really should be in the Orion or general troubleshooting subforum.
JerryFuller
- Noob
Re: Giza Freezup
I'll see about upgrading the software.
Wrong forum indeed. I don't even know how I would have gotten here.
