Hello Everyone,
I am a newbie when it comes to 3d printing. I have been printing for the last couple months to some pretty good prints but lately something has been wrong.
I dont have pictures at this time but i will as soon as i can but my bed seems to be warped or the towers are not aligned or something. The center of the bed is leveled which also includes a portion of the left side of the bed (between Z and X). Once it gets closer to the edge of the Z and X side of the bed, the problem happens. Now the problem is all over the bottom part of the bed (between X and Y) and the right side (Between Z and Y)
The problem i am talking about seems to be the nozzle moving higher off the bed when moving across the bed. For example where the bed is correct in the center of the bed the nozzle is perfect, calibrated, and the filament stick perfectly to the bed. Once it starts moving towards the problems sides the nozzle seems to go up just a bit (a tiny bit) but enough to make the filament now not stick to the bed and cause a whole set up problems.
I dont know if its the bed warped or the towers causing the problems. Can someone please help?
I have Rostock Max V3, all standard equipment
i built it myself
the prints were fine before, sticking to the bed
I've run calibration g29 and the calibration script.
I have yet to run the delta wizard (kind of confused on how to run it)
Please any help is appreciated.
Thank You
Bed Seems to be Warped (Or it could be the towers idk)
Re: Bed Seems to be Warped (Or it could be the towers idk)
I highly recommend using the delta wizard on SeeMeCNC's page. It will help your calibration quite a bit.
i was afraid that it was that easy. I will attempt the Delta Calibration Wizard and see if that helps.
Is there a reason why it started happening. I understand that parts tend to unscrew, things wear out and everything needs to be re-calibrated. It seemed to have happened over night
Ugh
i feel so stupid, it worked.
When i first built my printer, I didnt really understand the delta calibration wizard. After a couple months of working on the printer, calibrating a different way, and constant maintenance, i can say that i finally understand the delta calibration wizard. It was pretty easy and fixed my problem
Thank You
Thank You
It could be a number of things. Humidity, or a piece of debris getting under the bed, or even just bumping or bending something slightly.
Don't feel stupid. EVERYONE makes mistakes in 3D printing. When I started in late 2012, I had all the skill and poise of a giraffe falling down a flight of stairs. ![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
