Hey guys today i took the Challenge and installed my new FSR kit i got.
i started with buying metric screws
[img]http://i.imgur.com/YSpVJen.jpg[/img]
they were perfect i then drilled a hole with a m6 drill to make the nut fit tightly inside
Sensor facing side:
[img]http://i.imgur.com/KPVSpHD.jpg[/img]
Snowflake facing side:
[img]http://i.imgur.com/TrWscwZ.jpg[/img]
i then just screwed everything together with the 16mm long m3 Scews
[img]http://i.imgur.com/29038G1.jpg[/img]
<-- here you can see that the screw has tightened the nut moved into the plastic so the pressure is more evenly distributed.
i just used the same screws for the ones without the fsr plumbs and nutted them together with the snowflake to get them a tight grip.
[img]http://i.imgur.com/xSCIgKq.jpg[/img]
afterwards i used the Mhackney FSR Mounts i had to resize the plumbers to 98% to give them the good slipping fit they need.
Seconds before the first test
[img]http://i.imgur.com/f2nO12B.jpg[/img]
and IT WORKS
[img]http://i.imgur.com/8tiNx3v.jpg[/img]
thanks to the team for helping me out
i had to take the picture
[img]http://i.imgur.com/XQahdxX.jpg[/img]
DerZaubererer's FSR Montage
Last edited by derzaubererer on Fri Oct 30, 2015 2:53 pm, edited 4 times in total.
Re: DerZaubererer's FSR Montage
Thanks for your post but your images did not show up.
thanks i just fixed itEaglezsoar wrote:Thanks for your post but your images did not show up.
![Smile :)](./images/smilies/icon_e_smile.gif)
Yep, they work now! Great pictures and the cat picture added to my day! ![Smile :)](./images/smilies/icon_e_smile.gif)
The FSR setup looks good. I responded to your other post in my thread but it looks like you got it.
nice thats good to hear i just broke my borosilicate glass plate and i wont be able to print until maybe tuesday its a test to my patience:Ymhackney wrote:The FSR setup looks good. I responded to your other post in my thread but it looks like you got it.
i got a new glass and im currently trying to calibrate with the fsrs but its off by 0.2 mms and the opendact tool cant seem to fix it anyone got some tipps?
