That proves you are not working on it much because you have no spare time.mhackney wrote:Something I've been working on in my spare time. Almost got it down.
Cheers!
Thanks, Semper Bone! I would like to find some 3d printable models.geneb wrote:I tweaked the text a bit to help avoid that one.
FYI, nice Bone.
That would probably work.HComet wrote:If the SeeMeCNC guys included a small disk slightly smaller than the R4 bearing diameter with a 1/4" hole as a cut out on the melamine sheets then that could be easily used to push the bearings and sleeves together.
When I was still the TODO (technical order documentation officer) it wasn't done that way. The front page had the page change date, and the pages changed, then the changed pages would have the change date on the top. There'd always be the innocuous "This page left intentionally blank" pages throughout the manual as well.Windshadow wrote:Trying to think up things to make more work for Gene
I thought about a few things that cropped up during my build.
Now I expect most folks build their printers all at once or over a weekend of work at most.... but my build spaced out over about 12 or 14 days which I guess this is why i noticed this but I started with the manual dated Dec5 and I did not know about the changes made over those 12 days or so.
so I have several ways to improve the manual dispersion given the rolling dynamic changes that the engineering department impose on Gene.
an email from the sales department to folks that have recently bought a kit to get the new version of the manual... from http://download.seemecnc.com/rostockmax ... -Guide.pdf
or a note included with the kit and its invoice suggesting that the builder be sure to get the most recent version of the build and use manuals and to check
that the version date on the front cover of the build manual they get from http://download.seemecnc.com/rostockmax ... -Guide.pdf has
not changed if they start their build more than few days after getting the manual or if their build lasts more than a week or 2
perhaps a fresh post into the announcements forum when a new version goes up?
Of course if we really wanted to make it hard for Gene we could ask for mil spec documentation change notation with strike throughs and dated change lines
You want to cage the gyros to protect those pin bearingsgeneb wrote:You hear that funny little squeaking noise? That's the pin bearings in my eyeballs failing due to over-rolling.
Page #6, second sentence: "Special Note: If you see sections labeled “A” or “B” (ex. 6.7A), those sections cover the same task, but with different parts!"
It's even in bold. I'd make it blink if I could figure out how.
[Edit: I'm uploading a new version that has clarifying text regarding where to get the 14", 18ga wires.]
I used heat shrink tubing.bvandiepenbos wrote:ya, sorry, somehow I totally missed the two different sections for idlers.
just noticed that today. duh.
also, my kit had BLUE 26awg wire not white for the tmist wire in X column.
no biggie, just mentioning it.
hmmmm, Kapton tape the wire splices? well, that's original.
suppose it works, but it IS butt ugly
I hope that you didn't get the blues over this.geneb wrote:BLUE?!
*facedesk*
Dammit JJ!
Yes, Kapton insulation is kind of ghetto, but it gets the job done. That and I can't really justify asking a builder to buy a 3' length of heat shrink when they're only going to use about 3" of it. (and invariably, someone would use it on the hot end and you know how THAT would end...)
Chances are that your carriage is making physical contact at about the same time as the endstop switch. When you move it manually, is there a reasonable gap between the carriage and the wood when the switch clicks?terratian wrote:Working through the user manual for my max 2. I have just done my first movement test on page 23. All motors move to the switch but the x axis makes a very loud stuttering noise for about 10 seconds before it stops.
