can someone delete this?
can some one delete this?
Re: 6ft tall Rostock Max build!
s
moved to new thread
you're supposed to print a belt spacer clamp thingy to secure the belts.
Rostock Max V2 with mods:
E3d v6 with 713maker mount & e3d titan extruder
Tricklaser CF arms, heat spreader, tricktrucks, fly-n-strude, metal carriage & effector
Duet v.8.5.0
24v MeanWell 750w PS & Cydom D1D40 SSR in parallel with stock 12v PS
Duet v.8.5.0
Well I did that, but I think the spacers were ment to be used with all but the max metal brackets. So they didn't fit at all when I tried to use them. I'm not sure what else I can do. I haven't install the carbon arms yet because I just don't think the whole configuration of the belts and mounts is sturdy enough. I'll post pics in the morning of the belt clamps not working.
Belt spacer clamps are not used with the TrickLaser brackets.
SeeMeCNC belting is thicker than some others and works better. If needed, a few layers of kapton tape or some other type of shim material placed in the slot will increase the clamp pressure.
Re: can someone delete this?
Derp. It's ironic that I just hit the same issue with my new build lol. He actually supplies some.... aluminum tape looking shim material with it.
Duet v.8.5.0
Duet v.8.5.0
