Xenocrates wrote:Could you check your Homedelta.G for me, and tell me what it says? Also, I believe you need E1500:1500 to account for dual nozzle. Is the extruder failing to work something that you've tried using either a paneldue or DWC to check, or is that just a printing a file thing?
I was wondering about the E1500:1500. I've tried it both ways, I'll switch it back to that. I have my Macbook networked to it and I'm controlling it through the browser. I haven't tried a print yet, I'm still trying to calibrate it. None of the motors work. X,Y,Z,E0,E1. My homedelta.g is,
; Homing file for RepRapFirmware on Mini Kossel
G91 ; use relative positioning
;******* Change F250 in the following line to F2500 when you are finished commissioning
;******* Change 320 in the following to a higher value if your Kossel has taller towers
G1 S1 X320 Y320 Z380 F2500 ; move all carriages up 320mm, stopping at the endstops
G1 S2 X-3 Y-3 Z-3 ; move all carriages down 3mm
G1 S1 X6 Y6 Z6 F250 ; move carriages slowly up 6mm, stopping at the endstops
G1 Z-5 F2000 ; down a few mm so that we can centre the head
G90 ; back to absolute positioning
G1 X0 Y0 F2000 ; centre the head and set a reasonable feed rate
