bad side,
better side,
anyway to improve quality of this print?
rocket print
rocket print
untitled86
Re: rocket print
What caused that bad side?
Re: rocket print
bowden extruder, thats what it does during layer changes, haven' been able to figure out how to tune that out yet.
DaGroundZero
Re: rocket print
You might try changing your slicer settings to do a random starting point. I had that same issue but it was much better when I changed it. I took it off to test it again, and I'm seeing the issue again.
Re: rocket print
[quote=" I took it off to test it again, and I'm seeing the issue again.[/quote]
??? are you saying it didn't solve your problem?
DaGroundZero
Re: rocket print
I was just saying it seems to help my prints when I have that option checked.
untitled86
Re: rocket print
It's got to be more than the random start option. I've got that checked, my part is perfect except for this issue. It always screws it up going up on the Z axis. I'd love to know how to fix it.
Re: rocket print
kisslicer has a seam setting that ranges from 0-1, i think this is what i need to adjust to minimize that seam. currently it was set to 1, i'm going to try 0 and see what happens.
