Pictures help me a lot ... Thanks a million guys!
-SD
Leeway wrote:The J head hot end I use came with some PTFE tube around the wires. It is pretty cheap. Bought some as spares from Mcmaster Carr.
5335K114
HI-Temp Chemical-Resistant PTFE Sleeving .015" ID, for 28 AWG Wire, 10' Length
In stock
Quantity Per Ft.
1-99 Ft. $0.16
100 or more 0.12
http://www.mcmaster.com/#catalog/118/821/=gzlf8x
Yes, the teflon tube that comes with the kit needs to go into the nozzle until it stops. If it doesn't the ABS/PLA will pool up in the tip and you will have a mess on your hands.Racer wrote:Is the Teflon tube that come with the H1 kit hot end, suppose to go all the way in to the brass nozzle?
michaellatif wrote:Yes, the teflon tube that comes with the kit needs to go into the nozzle until it stops. If it doesn't the ABS/PLA will pool up in the tip and you will have a mess on your hands.Racer wrote:Is the Teflon tube that come with the H1 kit hot end, suppose to go all the way in to the brass nozzle?
I have the old style nozzle (extruder assembly) that does not capture the teflon tube and once in a while it will push upwards and pool up the ABS in the tip. I would then have to take the extruder tip off and heat the tip with a heat gun (till its extremely hot - do this in a well ventilated area!) and scrape out the goo.
