While tweaking my V3, I managed to jam it all up
- ido3dprintz
- Prints-a-lot
This printer is a trooper. She kept going and going through the struggle. It looks like I have a partial clogged extruder assembly. Thoughts? I have never cleaned one before so I'm hoping I don't have to tear this whole HE280 apart to fix it.
[img]http://i1250.photobucket.com/albums/hh5 ... z5cgsm.jpg[/img]
[img]http://i1250.photobucket.com/albums/hh5 ... v6y9wg.jpg[/img]
It continued to print in a "failed" status, looks real bad and patchy. I cancelled the print and tried to remove the filament. It came off right at the end of the bowden tube when I pulled the retention clip off.
Not sure how much is still inside.
 n00b in training, willing to learn and absorb all that I can for this hobby
Re: While tweaking my V3, I managed to jam it all up
Start with that extruder. You will probably need to remove it and pen it p to clean all that ground filament out. That is probably your issue, the other end (the hot end) is probably just fine.
PS 3D printing is not a hobby, it's a lifestyle!
- ido3dprintz
- Prints-a-lot
That would be great if its just the EZR. Would a bad setting cause this? Like the EZR is trying to put too much filament through the nozzle that cant handle it?
It could have been caused by a lot of things. How much experience do you have? Have you had 1 reasonably good print? If so, your slicer settings are likely fine. What were you tweaking? That's the place to start.
- ido3dprintz
- Prints-a-lot
I have had amazing prints ever since I switched to SD card printing (like I have always done on other printers).  Mattercontrol from my junky laptop caused pausing/blobs/zits so I still use it to slice and save gcode to SD- so much better. Stringing has always been an issue so I changed retraction settings a bit and got a decent looking slime rancher.
My mistake was trying to speed this rig up I think. I was hoping for something faster than a snails-pace and then let it rip. Stringing came back and the EZR jammed all up.
[img]http://i1250.photobucket.com/albums/hh5 ... venacg.jpg[/img]
I
I
- ido3dprintz
- Prints-a-lot
Success!  Then Epic FAIL yet again. I'm at a loss....
I decided to try the bandaid gcode so there was no possibility of me messing it up. After cleaning out all the red PLA fragments from the PTFE and the EZR I gave it a try. It printed OK. The results are not any where near as nice as Michael's in that the corners are doo-doo and the top layers seem not enough, but it was a successful print.
[img]http://i1250.photobucket.com/albums/hh5 ... 3fjb5r.jpg[/img]
I then decided to throw a Benchy at it using the KISSlicer and Michael's profile I imported......once again, trying to not make a problem when it is MY doing..... So I sliced and began to print. Came back after a bit to discover the EZR is now starting to have fresh white dust all inside it, and the motor gear is 1/2 gummed up just like the red PLA did (ended up canceling part way through). I could see it trying to print, but it was struggling.......what else could I look into next to see why it does this?
I get clean pulls through the PTFE so I dont think it is binding up in there
[img]http://i1250.photobucket.com/albums/hh5 ... ztdz0k.jpg[/img]
Is the extruder clicking?
Can you feed through the boden and hot end by hand (holding the release and pushing).
- ido3dprintz
- Prints-a-lot
Yes, sometimes it is clicking. I can see the motor running and not pushing filament. On the Benchy.
On the bandaid, it worked no problem that is why Im lost.
Have you checked that the extruder's gear is aligned with the filament?
Then slow down to 25/s and see what happens.
Retraction setting changes can cause the issues you are describing.  I made changes to my my V3 and lost track of what I changed so I went to MatterHacker and added my printer again with a new name and that will load all the default settings so you can at least start from a known starting point.
Best of luck!
							Best of luck!
Self designed plasma cutting table running Mach3
Orbot Hadron running and E3d 6, Smoothie on an Azteeg Mini, LCD, fully adjustable glass bed of my design with a silicone mat heater.
Prtrbot Simple Metal
Table top CNC running Mach 3
- ido3dprintz
- Prints-a-lot
The official name for this printer is Britney Spears, or Britney for short, because oops, She did it again.
I decided to start fresh as mentioned above. While I was at it, I did check the alignment of the filament and the gearing and it looks good. I re-printed the bandaid using Cura as the slicer of choice with Michael's settings and it came out almost perfect; even better than the Kisslicer one did. The first layer had a few issues, as you can see from the picture, but eventually worked itself out.
[img]http://i1250.photobucket.com/albums/hh5 ... okmeqy.jpg[/img]
Feeling confident, I decided to give it a retraction test file to see the "stringing goodness" this machine likes to give me no matter what I seem to do and DISASTER strikes yet again. I didn't change a thing. Used same slicer, same settings as earlier and this happens:
[img]http://i1250.photobucket.com/albums/hh5 ... rzvdzo.jpg[/img]
You can see where it was slipping on the extruder at first almost 1/2 way up the print, then it "fixes" itself to give nice layers till the super stringing starts back up. I think this is a every-other-time printer. I get one good, then one bad with nothing changing at all.......
See if this is your problem http://forum.seemecnc.com/viewtopic.php ... 373#p48928
							Orion to Cartesian     http://forum.seemecnc.com/viewtopic.php?f=59&t=7808" onclick="window.open(this.href);return false;
						- ido3dprintz
- Prints-a-lot
Thanks for the link to check. Ill go back and look again, but I'm pretty sure the gear was normal at last glance.Holy1 wrote:See if this is your problem http://forum.seemecnc.com/viewtopic.php ... 373#p48928
Did you ever sort out your extruder grinding and chewing up filament into pixie dust?  My V3 just started doing it out of nowhere, and I haven't changed anything settings wise.  Curious if you nailed the fix down. Thanks.
Scratch that last post and thanks for that link! I just checked my hobbed bolt and its machined goofy, almost smooth. This is my first run of PETG through so I guess the greater softness than PLA is making it lose traction. Time to take pics and submit a ticket for replacement.Holy1 wrote:See if this is your problem http://forum.seemecnc.com/viewtopic.php ... 373#p48928
