I am thinking to put this platform to work on my V2.
Mount : http://www.thingiverse.com/thing:1907968
Platform : http://www.thingiverse.com/thing:1284511
I printed both in ABS, layer adhesion is fine. I have been using the mount for quite some time already, but the fan assembly will be my first. I want to give it a try on my V2. Will it be rigid enough for FSR probing? An other concern is if the part fan that sits quite next to the peek fan will not obstruct the function of the peekfan (with clogging the HE as a result). Does anyone happen to use this platform together with a E3D HotEnd?
The fan assembly is originally jimustanguitar's design, but I found one adapted for the ball-cup joints.Treat for my V2
- DeltaCon
Treat for my V2
- DeltaCon
Re: Treat for my V2
Jimustanguitar: did you ever use this platform in combination with an E3D hotend?
Did the layerfan not block the peekfan too much?
