Hi everyone!
Lately I am having issues with the seams on some of my designs (see pictures below). I am having these issues on both my Rostock Max V3 and BQ Hephestos 2 using Cura v2.3.1. Does anyone have some tips about which settings I could tweak in order to reduce or fix this issue?
Some settings of the print in the picture:
Printed on the Rostock Max V3
Layer height: 0.3
Temperature: 195
Enable retraction: off
Outer wall speed: 40
Inner wall speed: 60
[img]https://d2py9w124w2itd.cloudfront.net/p ... G_2766.JPG[/img]
[img]https://d2py9w124w2itd.cloudfront.net/p ... G_2765.JPG[/img]
Ugly seams, under extrusion?
Re: Ugly seams, under extrusion?
If you increase your layer thickness you need to increase your temp accordingly.
I print .32mm layers at a minimum of 210 most of the time at 220 due to the high print speed.
Up your temp to 210 for a start to see if you see any change on the same part.
Remember, only change one thing at a time.
Current printers
Rostock Max V3 (built but not printing yet)
3 x Flashforge Creator Pros 2016
3 x Prusa i3 mk2
Flashforge finder
Wombot Modus
Cocoon Create (Wanhao i3)
3 x Prusa i3 mk2
Flashforge finder
Wombot Modus
