Should I try a different hot end???
Since the only "cash" I have is in the form of amazon store credit and seemecnc doesn't accept amazon payments any longer, is there another hot end that works well with the V3? I currently have the HE280 and love it, but Amazon doesn't have it, so I am considering a different hot end. E3D?  My current HE280 accelerometer board is fried and needs replacing.
Re: Should I try a different hot end???
If the accelerometer board is fried, switching to an E3d, or any other hotend doesn't make sense.
Sorry, I should've been more clear. I cannot get the stock HE280. What other hot end will work? Any other accelerometers work?Mac The Knife wrote:If the accelerometer board is fried, switching to an E3d, or any other hotend doesn't make sense.
From what you've said, you've got a fried accelerometer, but a perfectly good hot-end currently. You aren't clear in what way the board is fried, but I suspect you could unplug the I2C connector and use it as an ordinary dumb hotend right now. Yes, you'd have to calibrate manually, but you'd have to do that with a 3rd-party hot-end as well. If you're looking for another hotend with integrated accelerometer feature that plugs into the V3, you won't find one.
You can find another accelerometer, but not one that would be plug and play on the V3. Aside from mounting issues, you would have to integrate it into the software yourself. I don't get the feeling that's within your skillset.
Thanks.  I just received my new he280 from seeme and installed.  Same issue!  Has to be the Rambo at this point, I think  Led 4 lights up red, then the lcd shuts down and restarts when turning on either the heat or fans.
  Led 4 lights up red, then the lcd shuts down and restarts when turning on either the heat or fans.Re: Should I try a different hot end???
Check your power wiring.
