Duet 0.8 tplink 702n config problems
Northspire
Post by Northspire »
Hi
I am trying to configure my duet board for wifi with a tplink 702n router. I can get the router to connect to the wifi but I cannot connect to the duet. Any ideas?
Rostock V2 Meanwell SP 750-24 Power Supply,710n Nano W/l Router,E3D Chimera Hot-End,713 Maker Effector and Hot-End Mount,Duet 0.8.5,Bondtech QR Extruder,PanelDue W/ 7 Inch T/S,Mini IR Height Sensor,24V Heated Bed With SSR,46 Quart Dry Box.
IMBoring25
Re: Duet 0.8 tplink 702n config problems
Post by IMBoring25 »
The 0.8 does not have WiFi and has to be connected over Ethernet cable. Thus the new version...Duet WiFi.
DeltaCon
Post by DeltaCon »
I think Northspire is aiming at getting a router to interconnect between a wifi AP and the cabled Duet. Many more have done this but personally I have no experience with Duet 0.8. I do have experience with WiFi bridging. If it is a "normal" router, you will probably have problem. In most routers the wifi connection cannot be used as an uplink. Routers that do support that have usually a setting under the name "bridge". You best get a model that is specifically intended for this purpose, without DHCP server and DSL or external ethernet connection, because it does not have to translate from one network to another.
Northspire
exactly. I have A Linksys wifi router connected to the internet and I want to use the tplink 702n nano router in client mode to connect the printer to the network.
dc42
Post by dc42 »
I had a similar setup working some time ago using the wr720n nano router. I had to connect a laptop to it with an Ethernet cable to set it up. AFAIR I configured it in client mode with auto DHCP. I configured the Duet to use DHCP.
marcom
Post by marcom »
I have a similar setup - Duet 0.85 with TPLink 802n.
- Log in to your TPLink admin console (at your TPLink's IP address)
- Change your Operation Mode to "Client"
- Make sure under "Wireless" > "Wireless settings" your router's name and MAC address are correct (for some reason this matters - I switched routers and lost connectivity once and this setting still had my old router's MAC address and changing it seemed to fix it). Also I have WDS disabled, but dunno if that matters or not.
My IP lines in config.g:
M552 P192.168.185.120 ; IP address (0 = use DHCP) - I use an assigned address so I can connect to it by IP if I have to.
M554 P192.168.185.1 ; This is my main router (not my TPLink - that one has a different address)
M553 P255.255.255.0
Hope this is helpful.
Rostock MAX v2, Prusa i3, Makerfarm Pegasus
Return to “Duet”
