- I removed the bowden tube from the hot end and clipped the filament at the end of the tube
- In Matter controller told it to Extruder 100mm of filament. The printer did so. I measured it.
- Then I manually wound it back up to the spool and lined it up with the bowden tube with the nice blue knob with the eyes on it.
- In Matter Controller I told it to extruder 100mm MORE filament. Nothing Happened.
All the other controls responded Home/Z/Fan
- I tried E+/E- larger and smaller numbers 1/10/100mm. Nothing happened.
- I disconnected the printer from MC and re-connected, then tried to extrude again. Nothing happened.
- I disconnected the printer from MC. Turned OFF the printer. Physically unplugged from USB and power. Opened up the top and checked all the cable connections to the extruder. There are no signs of damage and the connector is plugged in tight. I unplugged it and plugged it back in to check. And followed the cables back to the motor with no obvious sign of damage.
- I reconnected everything and tried again... still nothing.
- Just for the heck of it, I decided to try to print... and see if THAT could move the extruder motor. It did! It printed.
- I removed the bowden tube from the hot end, clipped the filament, and told it to extrude 100m more. It did. I measured.
- I tried for a 3rd so I could get an average... nothing happened, again.
All of the other commands worked as expected. I could open the terminal and watch the "G91 G1 E100 F150 G90" commands being sent to the printer every time I requested filament. I could even see the "E*" value change to the value extruded/retracted, but it did not do anything. I was also able to successfully change settings in the EEPROM.
Any ideas as to why after extruding 100mm of filament I can't get the extruder to respond to MC again without physically starting a print. Queuing the print it didn't do it, it actually had to start the print process. Once it started, it was good to go for one more try.
I am on a Rostock Max v3 on Windows 10 with MatterControl 1.6. Connected via USB. If it matters I'm using com7 and 250000 Baud Rate. (Side note I am running UN-modified Firmware 20170201 Repetier_0.92.2)
Willing to work on figuring out. I know I have a work around by printing something, but I'd like to be able to extrude more than once at a time without having to stop and print.
And just in case it makes a difference the "weird" results I was getting to start the whole thing off were that while printing the flow rate would just seem to stall or slow down without reason. Sometimes the extruder would click once or twice, but not always. I have been working on adjusting the temperature/flow since I switched to a new filament roll.
Thanks much, and in advance you guys have been great.
Matthew (TaggedZi)
