Applying PEI
Applying PEI
I already have a glass+PEI sheet as my primary surface, but there are microbubbles. I was just thinking to lessen the variation during cal and whatnot, has anyone tried applying it wet? The first time I did it I failed miserably so the second time I just applied it dry and squeegeed it as best I can. I planned to get more surfaces to swap out which is why I ask.
Re: Applying PEI
This may be a silly idea, but...       How crazy does it sound to try applying the sheet while it's completely submerged? You could find a cake pan or something like that and easily mix water and a drop of dish soap to make a chamber to do the application in...
I might have to try this on my next one.
- lightninjay
Re: Applying PEI
To my knowledge, this is the way that most forum members have applied theirs.djarmag wrote:I already have a glass+PEI sheet as my primary surface, but there are microbubbles. I was just thinking to lessen the variation during cal and whatnot, has anyone tried applying it wet? The first time I did it I failed miserably so the second time I just applied it dry and squeegeed it as best I can. I planned to get more surfaces to swap out which is why I ask.
If at first you don't succeed, you're doing something wrong.  Try again, and if it fails again, try once more.  Through trial and error, one can be the first to accomplish something great.
						Re: Applying PEI
I might have just squeegeed a bit too hard and/or put too much water, I've done tint/car wrap/phone screen protectors, but this PEI adhesive was a pain in the arse. Did you apply it to the Glass or PEI first?
