yes sure please i can do everything to get it sorted i use PETG 233 extruder and 65 bed temp
now moved a bed clockwise 1 point and make again deltacalibration manualy
and got
Success! Calibrated 7 factors using 10 points, deviation before 0.06 after 0.02
but still ring callibration fail
photo show where is 3 points thats filament not stick to bed  (All screws tightened)
again manual callibration
G29
then
delta
results
 Success! Calibrated 7 factors using 10 points, deviation before 0.05 after 0.02
same points as on the pics up no stick , im going crazy
printed from SD same resoults
now conected back to octoprint and run deltacalibration plugin on
Calibration Result: Calibrated 6 factors using 10 points, deviation before 0.07 after, 0.03
octoprint same results always this 3 points not stick to
bed where deltacalibration is not sensing thish points
is no matter what slicer i use  first photos is mattercontrol 1.6  second and 3 is Simplify3d
now where is this 3 red arrow i put under the bed (this mounting points ) 2 layest off blue tape
run octoprint delta plugin and got
Calibration Result: Calibrated 6 factors using 10 points, deviation before 0.06 after, 0.02
printing now
still same the arrow points not stick to bed
moved hotend clockwise and run octoprint delta plugin
Calibration Result: Calibrated 6 factors using 10 points, deviation before 0.08 after, 0.01
whaaat ???? how this possible
run again
Calibration Result: Calibrated 6 factors using 10 points, deviation before 0.03 after, 0.01
