Knocking prints to the floor
- gsnover
- Prints-a-lot
So on 3 occasions, always while I have stepped out, my rostock loses position and then knocks the print out the build platform. I can see evidence of the side of nozzle hitting and meting the plastic near the top edge. I am running slow speeds 30 mm/s print/infill 150 mm/sec travel. No evidence of warping or lifting. What could cause this? I haven't seen it happen cuz I don't have the luxury of sitting and watching my prints
Anyone encounter a similar problem?
Rostock Max - Shakira "her hips don't lie"
Rambo 1.1 | Onyx | LCD | Marlin-for-Rostockmax-RamboLCD
KISSlicer
KISSlicer
Re: Knocking prints to the floor
Short version is no I haven't seen it happen.
Does it always happen at a similar height above the bed?
It could just be poor adhesion to the bed.
It could be you're losing steps on one axis, or have a lose gear on a stepper, what this does is tilt the plane of the print.
You really need to see it happen.
- gsnover
- Prints-a-lot
I was going to add that I am running off the SD card. It has happened on different prints at different heights. I don't think it's an adhesion problem because I haven't seen any curling or lifting yet.
But I will run the last print again and watch it, see if it happens the same way twice. I guess I have my weekend planned
KISSlicer
KISSlicer
- elqisqeyano
Where can we purchase new gears at? I think mine are failing. Can you include site and part # please?Polygonhell wrote:Short version is no I haven't seen it happen.
- elqisqeyano
Check your belt tension and motor timing pulleys. Belts have to be tight! Motor pulleys could be getting stripped.
Seemecnc sells them, they are they are the newer 20 tooth gears that they are now shipping.elqisqeyano wrote:Where can we purchase new gears at? I think mine are failing. Can you include site and part # please?Polygonhell wrote:Short version is no I haven't seen it happen.
Under accessories, belts and pulleys, 3 for $20
- elqisqeyano
Eaglezsoar wrote:Seemecnc sells them, they are they are the newer 20 tooth gears that they are now shipping.elqisqeyano wrote:Where can we purchase new gears at? I think mine are failing. Can you include site and part # please?Polygonhell wrote:Short version is no I haven't seen it happen.
My gut instinct tells me to go for the technical advice; however, I've got to ask:
Do you have a cat?
Do you have a cat?
http://dropc.am/p/KhiI1a
- gsnover
- Prints-a-lot
Hahaha, that is funny. I wish it were that easy. No cats.
I stripping down the arms for more sanding and checking the belts and pullies.
KISSlicer
KISSlicer
