Orion will not home
Kevinvandeusen
Orion will not home
Post by Kevinvandeusen »
Someone came in my store today, and decided to play with the lcd controls. Now when you ask to home, it just goes down about 25mm. I am baffled as to what they must have changed?
bot
Re: Orion will not home
Post by bot »
I think they set a new Z height at an absurd value. Try resetting it to a sensible value.
*not actually a robot
briankb
Post by briankb »
I'm having this issue right now and it was because I accidentally pressed on the "Set Z Height" menu item. I have tried, what I thought would correct it, but it still only goes DOWN when I press Home. I would expect it to go UP when I ask it to home until it hits each of the switches.
What I've tried to no avail:
- manually move the hot end tip to just above the center of glass and resetting Z Height via same menu that got it messed up in first place.
- tried running Calibration which I assume would just ignore existing settings and start from scratch.
joe
Post by joe »
You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and then go ahead and then calibrate the z height normally.
briankb
Post by briankb »
joe wrote:You could reset the z height in the eeprom( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally.
Isn't that what the LCD Menu "Set Z Height" does? I tried that a few times to no avail.
joe
Post by joe »
Sorry, forgot to mention the you should do it in the eeprom first THEN use the LCD menu.
briankb
Post by briankb »
joe wrote:Sorry, forgot to mention the you should do it in the eeprom first THEN use the LCD menu.
That worked. thanks Joe!!!!
joe
Post by joe »
Sweet. You are most welcome.
tomcapizzi
Post by tomcapizzi »
By saying: "You could reset the z height in the EEPROM ( it's probably showing a weird number) to approximately the right value and the go ahead and then calibrate the z height normally." You are saying that I should re-send the Repetier config file back to EEPROM?
My menu selection on the Orion console for EEPROM settings are "Store to EEPROM" and "Load from EEPROM", I have wiped the EEPROM and resent the config file numerous times back to the RAMBo board with no change in results. When I home the printer, the head lowers about 1", and it will not configure Z height correctly.
matanyabs
Post by matanyabs »
have you found a solution? having the same problem
pouncingiguana
Post by pouncingiguana »
The easy way to fix the problem (assuming you've got the newer hot end with the probe) is to connect with MatterControl (or whatever) and open a terminal. Run M502, M500, G29. This will reset the EEProm to stock values, Save, then calibrate to set your endstops, z height, and horizontal radius.
