Firmware and motherboard issues for rostock max v3
Tyler_Sunshine
Post by Tyler_Sunshine »
Hi, i purchased the rostock max v3 around december and have put it on hold for a while after i built it and when i plug the printer in the wall and my computer and upload everything the lcd says something along the lines of, "seemecnc rostock max v3 repetier version 0.92.2" when the online guide says it should just have the temperature of the nozzle and bed. Ive reuploaded the firmware the drivers and cleared the eeprom dozens of times and still when i connect to matterspace it wont move at all, please help I am in dire straits and would really like to have this printer up and movin. Thanks!!!!
Re: Firmware and motherboard issues for rostock max v3
Has it worked before, is this a new symptom?
borrillis
Post by borrillis »
I've seen this problem when the whip is not properly seated in the hotend.
Tyler_Sunshine
Are you talking about the big black insolated cord with a bunch of different wires inside, because i checked and to my knowledge it it properly secured and no the printer has never worked, if you think anything else would be interfering with it please let me know Thanks!!!
I had trouble with the polarity of the thermistor wire in the hotend bundle. The accelerometer board uses the ground from the thermistor, so if you have the wires switched it tries to get ground through the data communication pins. Is the yellow tx/rx serial light on the Rambo flashing like crazy when you turn it on?
Tyler_Sunshine
not at all
pouncingiguana
Post by pouncingiguana »
This sounds like a wiring issue. Double check your whip wiring on both ends. If it's wired incorrectly it'll produce this exact problem.
Tyler_Sunshine
I briefly checked it this morning before i left for school and it looks to me like everything to do with the whip is connefted right, could it possibly be anything else? Please let me know and thank you all for the responses!!
pouncingiguana
Unplug your I2C wires from the Rambo board. It's the red and black wire in the 4 pin connector. If it gets past the boot screen it means that your wiring for those wires is incorrect.
Tyler_Sunshine
I will try when i get home thanks for the feedback
Tyler_Sunshine
And what do you mean by the boot screen?
pouncingiguana
The boot screen is the screen that shows the firmware version and date for a second before it switches to the temperature screen
Tyler_Sunshine
Yea mine doesnt do the temp screen but youre saying if i unplug the red and black wires it will?
pouncingiguana
I'm saying this is a way to find out if the I2C wires in the whip are wired incorrectly.
Tyler_Sunshine
I unplugged the red and black wires from the whip from the rambo and nothing happened, could anything else be wrong?? Thanks!!
Tyler_Sunshine
update: i unplugged the whip itself in the bottom and plugged it back in and now the LCD says what its supposed to besides the nozzle and bed says DEF, what should i do?
Post by Xenocrates »
See forum.seemecnc.com/viewtopic.php?f=37&t=11836&p=104306
I don't know why, but links aren't working for me currently.
Tyler_Sunshine
it says page not found
and here I see the "Dreaded DEF troubleshooting guide"
Try this
It seems only my laptop is offended by links.
Tyler_Sunshine
Do you know how to tinker or alter with the PID?
Tyler_Sunshine
update: when i turn the printer on it says what it isnt supposed to (on the lcd) like the make and model and "fw date" and repetier version but when i unplug the whip it goes to the speed and temp of the noz and bed and says 22 for both (what its supposed to say) but then it says def right after and i plug the whip back in and nothing changes, please help if you have any info at all, thank you all so much!!
borrillis
Post by borrillis »
If your LCD panel get's to the Temp screen without the whip plugged into the hot end, and freezes when it is plugged in, then it sounds like you have faulty wiring in the whip. Head back to the manual and double check both your connections to the rambo and the connector at the hotend to make sure everything is routed correctly.
When the whip is connected, are any of the led's on the hotend lit?
pouncingiguana
Your whip is wired incorrectly. If all the colors look like they are in the right order, you probably have them in the connector backwards. Double check the orientation of the connector and reverse all the wires. Willing to bet this will fix your problem
Tyler_Sunshine
No the leds arent lit on the hotend
KAS
Post by KAS »
Might be best to take a few pics and post them
