turned it on all the red lights lit up
NaderHatami
Post by NaderHatami »
I have a probleb with rambo ver 1.2
When i turned the board on (Pluged the powers) green led lits up after that all the red lights lit up without any control.
U.S. Water Rockets
Re: turned it on all the red lights lit up
Post by U.S. Water Rockets »
You should try to load the repetier software, then check the LED behavior. Maybe some other program is loaded that's turning stuff on.
czecht
Post by czecht »
Have you fix the problem? How exactly did you get rid off the RED LED on Rambo board?
