I am installing the FSR probing kit from Ultibots on my Rostock Max v3, following Michael Hackney's instructions on his blog (thank you Michael!).
The only issue I am running into is where to route the wires from the JohnSL board in the base to the Duet 3D board in the top. I thought maybe the tower extrusions, however there is no room. Suggestions?
Thank you!
FSR Wire Routing
Re: FSR Wire Routing
Check this out: http://forum.seemecnc.com/viewtopic.php ... 187#p58187
Thank you! I ended up doing just that.
