Hello, I usually don't post, I am usually able to find the answer going thru the forums, but not this one.
For some reason when I use the macro for bed center, x and y go toward the bed but z doesn't.
G28
G0 z0 f3500
Macros for tower z,x,and y work correctly.
I have homed all axis g28, did the calibrate z height using lcd. Set endstops.
Firmware is Repetier 0.91
Any help or direction is appreciated.
CarlJ
Re: macro for bed center
Just for grins, try upper casing the Z and F commands and see what it does.
Hey, Thanks for the reply.
I hadn't noticed the lower case
Anyway I completely cleared eeprom and reloaded firmware.
Everything good now, Just keep my dobbers from trying different things.
CarlJ
CarlJ
