https://www.thingiverse.com/thing:2654679
I have some issues with the Rotary Encoder code..   If someone that is knowledgeable on that subject could take a look at the INO file on Thingiverse it would be appreciated.
						Watch Winder (could use some expertise on code)
Re: Watch Winder (could use some expertise on code)
What do you mean "some issues" ?
I don't want to open your code if I don't know what I'm looking for...
Did you deal with rebounds ? some rotary encoders bounce alot. Last time I used one, I had to add a low pass filter (capapacitor and resistor) to kill them rebounds before entering the arduino.
Rotary encoder bounce doesn't matter if the driver software is correctly written and only one contact bounces at a time. When I first connected a rotary encoder to an Arduino about 4 years ago, all the existing driver code I found was rubbish, so I wrote my own. If you want to try it, it's at https://github.com/dc42/arduino/tree/master/Libraries.
