Can't Add File To Library
I've been playing around with printer profiles, and quality and material presets to find the best way to support swapping nozzle diameters. I want to print a test object, but when I click on "add" a window should pop up allowing me to select my STL file. The main window behaves as though the file selection window is open, but I can't find it anywhere. I looked on all of my desktops. Is there a coordinate in a file that may have gotten corrupted?
Re: Can't Add File To Library
70 views so far, but no suggestions?
I am assuming that this is in MatterControl under Windows?
If you have already tried everything else, make sure that you are syncing all of your settings with the MatterControl cloud. Export any settings that you can. Then uninstall and reinstall MatterControl.
In any case, if this is a MatterControl issue, you should probably take it up with the maker (MatterHackers). The lack of replies may be because you're asking a software question on a hardware forum.
Good Luck!
Tim
Good Luck!
Tim
Better yet, try out Cura.
