PCB Board Rev 6a
Morriz
PCB Board Rev 6a
Post by Morriz »
Anyone has PCB Board Rev 6a schema?
Pin voltage / use?
Thank you,
Marcello
Re: PCB Board Rev 6a
Can you clarify what "rev 6a" pcb you're talking about? :)
Morriz
Post by Morriz »
This one:
https://www.seemecnc.com/collections/pa ... -pcb-board
that is different from rev 5a schemes on GitHub site.
Morriz
Post by Morriz »
I saw that on new Rev 6A of PCB there're new 2 pins socks named PROBE, LED and 3 FAN PART than 1.
What is the use of PROBE? Voltage In/out?
Voltage Out of LED? Always ON?
Thanks,
Marcello
I'm not sure what the changes are related to - I don't have one of the newer boards.
pouncingiguana
Post by pouncingiguana »
The probe pin locations are not used.
The LED pins are always on hooked to the main power for the hot end (nom 12v always on).
The three part fans are wired in parallel with each other.
The Heatsink fan is wired to the hot end main power (always on)
Morriz
Post by Morriz »
Thank you pouncingiguana
Marcello
Return to “RostockMAX v3”
