PLA & ABS Same Issue - Suggestions?
djamie
Post by djamie »
Hello all. I am having issues with printing a clamp in both PLA & ABS. There is globs of material in same area of both prints. I am using Matter Control software with MatterSlice slicer configured. I was thinking I should try another slicer, but interested in more experienced opinions (I am a rookie).
White PLA printed at 210, retraction 4.5mm length on move
Black ABS printed at 245, retraction 6mm length on move
Any other suggestions on improving prints welcome
3D Printing Setup
Rostock Max V3 kit - No Mods
Re: PLA & ABS Same Issue - Suggestions?
Post by Xenocrates »
Looks like a poorly tuned restart length, or else the retract speed should be tuned. Likely lower, as you're likely using an E3D-esque hotend, where to avoid jamming, the maximum length should be 2mm or less, and the speeds rather low. I would also make sure that your wipe settings are adjusted a little, and that you don't have a longer restart distance than your retract
djamie
Post by djamie »
@Xenocrates thank you. Gives me something to work with. I also should mention I am printing with Rostock max v3 kit with supplied hot end.
3D Printing Setup
djamie
Post by djamie »
@Xenocrates
Any suggestions on current settings? Any help appreciated
3D Printing Setup
I'd turn the retract length down to 2mm or so, and play with retract speeds down around 10-25mm/s
