Hi,
When I turn my machine on, it just constantly goes from the startup screen to the home screen on the LCD , like a loop. It just keeps doing it every 30 secs or so.
I am not very good with electronics, but to my best of my abilities I managed to isolate the problem to the usb connector. It only does the loop when the usb cable is plugged.
the printer actually works, it prints and everything.
Any insights will be greatly appreciated, Is my mobo done? What should I do?
thank you for your time.
Rostock max V2 Keeps restarting
Re: Rostock max V2 Keeps restarting
If the USB cable is worn, or either port, then as the connection is made and broken, arduino based boards will reset to allow updates. It may well just be the cable. Does this behavior happen with other cables, or other USB ports on your computer?
Thank you for responses,
I have tried different usb cables and yes, it still does the same.
