Rotate an object, does it work for you?
I'm using Repetier, and I need to flip an object 180 to get it to print, but the rotate function in Repetier doesn't seem to be working properly. Has anyone else gotten this to work before?
Re: Rotate an object, does it work for you?
Figured it out by reading the directions a little closer... You have to RIGHT-click the object to select it for rotation.
DaGroundZero
I was having some problems, but I realized that when it rotated, it moved it off the build plate. I just had to move it back. I zoom out when I do the rotate, so I don't loose it any more.
The center and drop tools become quite handy then.DaGroundZero wrote:I was having some problems, but I realized that when it rotated, it moved it off the build plate. I just had to move it back. I zoom out when I do the rotate, so I don't loose it any more.
