Firmware for duet 2 wifi not working
wellthad
Post by wellthad »
I have successfully installed the board the motors the new hot end and now I'm doing the firmware. I used rostock max v3.2 master files. I try to update firmware with M997 S0:1 and it gives me an error. None of the movement controls work if I try probing or just trying to move on an axis. I'm not sure what I'm missing.
wellthad
Re: Firmware for duet 2 wifi not working
Post by wellthad »
I can actually update the firmware now but after doing so I try going try first probe and it gives me more errors.
wellthad
Post by wellthad »
I think I got it but I'm getting height map error and it says I'm using S parameters when I should be using H parameters. I have no idea how to change that.
Screenshots of errors would be a big help in assisting your problem diagnosis. ;)
Return to “Duet”
