Hey poly, I noticed some issues at first with it as well and it ended up being the stainless portion was not perfectly aligned with the alu portion and created a minor little lip inside for things to catch and stall one.Polygonhell wrote:Just to give an update, I've pulled mine off the machine, I can't reliably print PLA with it, even ABS jams if I try significant retracts with it.
A lot to like about it, but it's too unreliable for the bulk of the material I print with.
Here's what I did to fix.
I took the nozzle offand the heater block.
Then I tightened the stainless into the aluminium after removing and cleaning it's threads. The purpose here is to get it to sit exactly where you want it to be for it's happy little life. Then I took a long drill bit the exact same diameter as the feed tube for the stainless (and aluminium) and ran this up through the stainless a few times on a drill to ensure that the path junction between the stainless and the aluminium portion were burr free and perfect smooth and aligned and met perfectly. I do not think they do this at the factory and the ever so slight edge catches the filament at the junction right at the thermal break and causes issues.
I never experienced the resistance that you mentioned with PLA or ABS. Try this out. I speculate that they manufacture the stainless and the aluminium seperately and ever so slight variances in the centering cause this little shoulder inside. After smoothing this edge out when you have things seated for your specific hotend I am betting you'll be golden.
Hope this helps.
I only discovered this because when I was tapping the threads for the PTF connector I ran the bit through to clean any possible shavings out that might have plugged the tip. Then I discovered the ever so slight edge I speak about and got it before my first use of the hotend.
