Long beep power issue
Bigneil222
- Noob
So when I’m using my Rostock Max V3, it’ll start a print go about two minutes then a long beep sound will happen freezing the entire printer. I can’t access the board and I cannot access the print menu. The only way around it is to turn it off wait, about two minutes and turn it on to restart the machine and I don’t know how to fix that issue. Can anybody please help me with this? Update as of 11:33am here if I even try to turn it on it has that solid long beep sound what should I do?
Re: Long beep power issue
I would check the output of the power supply.
Bigneil222
- Noob
I will check that and get back to you
Bigneil222
- Noob
So I unplugged it removed the location from where it was moved it over to a different wall outlet, plugged it back in turned it on and then it started to beep immediately the reset button also does not work. Unless I’m hitting a different button that I should to reset it.
That's not testing the output of the power supply.
Did you make any changes to the printer prior to the problem manifesting itself? (uploading firmware, etc.)
