Retract On Layer Change creating "-" Gcode Values.
elqisqeyano
Post by elqisqeyano »
When ever I check "Retract on layer change" in Slic3r it generates a negative value in the gcode. So as soon as Rostock goes into the second layer it digs into the bed due to Slic3r generating a negative Gcode value upon commencing into the 2nd layer. Is there anyone here that has experienced this kind of problem?
I am using Repetier Firmware and Repetier Host with Slic3r.
Re: Retract On Layer Change creating "-" Gcode Values.
elqisqeyano wrote:When ever I check "Retract on layer change" in Slic3r it generates a negative value in the gcode. So as soon as Rostock goes into the second layer it digs into the bed due to Slic3r generating a negative Gcode value upon commencing into the 2nd layer. Is there anyone here that has experienced this kind of problem?
Retract on Layer change should only affect the extruder nothing else, and it's quite likely it generates a negative value for than because it does a G92 E0 at the start of a layer.
Can you paste the GCode you think is causing the issue here?
elqisqeyano
I changed some stepper settings from 8 to 16 in repetier firmware and now it's not generating negative values. I tried different layer heights and it appears to have rectified the problem. At least I hope it did. I can't generate a negative value now, next time it does I will copy and paste to here. Thanks for the help though.
