Advice on Slicer Settings?
I have a new Rostock Max and am having trouble printing a nice calibration cube. There are gaps between the walls of each object I print.
I am using Slicer (v0.9.9), Repetier-Host (v0.85b) and the settings suggested in the "Rostock Max Assembly Guide" (v1.17).
Printing 1.75mm ABS at 240˚C onto Kapton covered Glass HBP at 110˚C.
Here is an image of how the prints are turning out.
- foshon
Re: Advice on Slicer Settings?
Larger picture please. Quick advice, do a search for calibration here on the site. There are several very good guides already available. A picture after going through those steps will be easier to diagnose.
Purple = sarcasm
Here's a better picture. I'm also new to the forum. Can you point me to some of those good guides that you have mentioned?
Thanks
Thanks
Well to start with you're extruder is skipping, either losin steps or slipping in the extruder.
What layer height are you printing at the top of the cube looks like it's too high for the nozzle diameter, but it could also be just filament starvation from the slipping filament.
I'm using a 0.3mm layer height with a 0.5mm nozzle. I'll have to look into the filament starvation issue. It consistently feeds fine when I manually extrude.
In order to find articles containing "calibration", enter Google and type in the following:
site:forum.seemecnc.com calibration
Google will then search this forum for the word "calibration"
Happy reading and welcome to the forum!
If you have access to some tiny metric drill bits you should also verify that the nozzle
is indeed .5mm It is rare but some Rostocks were released with .7mm diameter nozzles.
- foshon
Here's the links:
http://forum.seemecnc.com/viewtopic.php?f=54&t=1163
http://forum.seemecnc.com/viewtopic.php?f=54&t=1735
http://forum.seemecnc.com/viewtopic.php?f=13&t=17
Purple = sarcasm
Hey foshon, thanks for looking up those links for him. Such help is great, you are one cool dude!
- foshon
Lol, thanks!Eaglezsoar wrote:Hey foshon, thanks for looking up those links for him. Such help is great, you are one cool dude!
Purple = sarcasm
Thanks guys.
Fashion you have some pretty sweet link looking up skills. I tried looking for this info for a while.
The Google trick mentioned above is the right way to do this. I wonder if the seemecnc guys could create a google custom search and put it in the header of the website? That would helpoxident wrote:I tried looking for this info for a while.
