It appears to home the x-axis first and since it was near the plate it jammed into the rail and just kept going because the limit switch is at the top = a lot longer distance than the rail
1) Is there a way to get the repetier home button to act like the home on lcd???
Also In the mad dash I got snagged on the thermistor wire for the hot end and it pulled out
2) What should I use to clean the RTV out of the little hole to reapply the themistor?
